This command disables the Session-Reflector.
| restrict | Restricts only TWAMP control sessions to create test sessions and reflector does not respond to TWAMP-test packets tgat do not match a test session created by a control session. |
N/A.
If the you disable the Session-Reflector, the application terminates all current TWAMP test sessions. If you specify the restrict keyword, only TWAMP control sessions may create test sessions and the reflector will not respond to TWAMP-test packets that do not match a test session created by a control session.
This command was first available in ExtremeXOS 16.1.
